Date/Time: Thu, 16 May 2024 11:46:36 +0000
charting data
View Count: 1193
[2017-06-12 13:24:20] |
User420048 - Posts: 17 |
Hi, I cannot get my chart to show data. I am trying to use dtn iq feed for my charting. I funded my account for $33. The set up process is very not very clear. Can you help? Thanks, John |
[2017-06-12 14:13:30] |
Reading Internal Order ID file. | 2017-06-12 09:11:31 Reading Trade Orders file. | 2017-06-12 09:11:31 Reading Trade Positions file. | 2017-06-12 09:11:31 Listening on UDP port 22903. | 2017-06-12 09:11:31 Software version: 1568 | 2017-06-12 09:11:31 Uses New Spreadsheets | 2017-06-12 09:11:31 Usage end date: 2017-07-13 | 2017-06-12 09:11:31 Enabled for: Advanced Features. | 2017-06-12 09:11:31 Enabled for: Sierra Chart Historical Data Service. | 2017-06-12 09:11:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-06-12 09:11:31 Current selected Data/Trading service: CQG FIX Trading | 2017-06-12 09:11:31 Chart Update Interval: 500 | 2017-06-12 09:11:31 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-06-12 09:11:31 2017-06-12 09:11:33 Local computer time | 2017-06-12 09:11:31 2017-06-12 13:11:33 Local computer time in UTC | 2017-06-12 09:11:31 2017-06-12 09:11:33 Local computer time in SC Time Zone | 2017-06-12 09:11:31 2017-06-12 13:11:29 Server time in UTC | 2017-06-12 09:11:31 Local computer UTC time and Server UTC time difference: 4 seconds. | 2017-06-12 09:11:31 Program path: C:\SierraChart\ | 2017-06-12 09:11:31 Data Files path: C:\SierraChart\Data\ | 2017-06-12 09:11:31 OS Version Number: 6.2 | 2017-06-12 09:11:31 Locale Setting: C | 2017-06-12 09:11:31 IQFeed | Connecting. | 2017-06-12 10:01:21 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-06-12 10:01:21 * IQFeed | Connecting to Admin port 9300 | 2017-06-12 10:01:21 Socket (112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-06-12 10:01:22 Socket (112) | Shutdown and closed. | 2017-06-12 10:01:22 IQFeed | Disconnected from Admin port. | 2017-06-12 10:01:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-12 10:01:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:22 Starting DTN IQ Feed interface software. | 2017-06-12 10:01:22 Error starting IQ Feed interface software. Error code: 2 | 2017-06-12 10:01:22 * IQFeed | Disconnected. | 2017-06-12 10:01:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:22 IQFeed | Connecting. | 2017-06-12 10:01:25 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-06-12 10:01:25 * IQFeed | Connecting to Admin port 9300 | 2017-06-12 10:01:25 Socket (113) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-06-12 10:01:26 Socket (113) | Shutdown and closed. | 2017-06-12 10:01:26 IQFeed | Disconnected from Admin port. | 2017-06-12 10:01:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-12 10:01:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:26 Starting DTN IQ Feed interface software. | 2017-06-12 10:01:26 Error starting IQ Feed interface software. Error code: 2 | 2017-06-12 10:01:26 * IQFeed | Disconnected. | 2017-06-12 10:01:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:26 IQFeed | Connecting. | 2017-06-12 10:01:29 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-06-12 10:01:29 * IQFeed | Connecting to Admin port 9300 | 2017-06-12 10:01:29 Socket (114) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-06-12 10:01:30 Socket (114) | Shutdown and closed. | 2017-06-12 10:01:30 IQFeed | Disconnected from Admin port. | 2017-06-12 10:01:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-12 10:01:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:30 Starting DTN IQ Feed interface software. | 2017-06-12 10:01:30 Error starting IQ Feed interface software. Error code: 2 | 2017-06-12 10:01:30 * IQFeed | Disconnected. | 2017-06-12 10:01:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:30 IQFeed | Connecting. | 2017-06-12 10:01:33 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-06-12 10:01:33 * IQFeed | Connecting to Admin port 9300 | 2017-06-12 10:01:33 Socket (115) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-06-12 10:01:34 Socket (115) | Shutdown and closed. | 2017-06-12 10:01:34 IQFeed | Disconnected from Admin port. | 2017-06-12 10:01:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-12 10:01:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:34 Starting DTN IQ Feed interface software. | 2017-06-12 10:01:34 Error starting IQ Feed interface software. Error code: 2 | 2017-06-12 10:01:34 * IQFeed | Disconnected. | 2017-06-12 10:01:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-12 10:01:34 File >> Disconnect selected. | 2017-06-12 10:01:36 IQFeed | Disconnected. | 2017-06-12 10:01:36 Date Time Of Last Edit: 2017-06-12 14:23:23
[2017-06-12 14:22:46] |
This is the relevant message: IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-06-12 10:01:33 * You need to follow step 2 here: DTN IQ Feed Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
