Date/Time: Thu, 16 May 2024 13:26:22 +0000
Spreadsheet study and write to bar data study
View Count: 948
[2017-06-11 21:20:40] |
User182649 - Posts: 31 |
When utilizing either of these studies, is it possible to specifically pick which study values are exported. For example, both the bid and ask volume are exported and theses columns are empty. I neither need nor want these values exported. Thanks
[2017-06-12 18:11:20] |
No, there is not. Bid Volume and Ask Volume are always exported. You can always remove those through Spreadsheets by opening the file, and deleting those columns and saving it. http://www.sierrachart.com/index.php?page=doc/WorkingWithSpreadsheets.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
