Date/Time: Thu, 02 May 2024 13:50:43 +0000
market depth and level 2 data
View Count: 2910
[2017-06-10 22:55:07] |
Yamin2000 - Posts: 31 |
HI i notice that Sierra Chart does not provide market depth and level 2 data (in sc Real-time and Historical Exchange Data Feed) for US equities so can i use Interactive broker and sc real time in the same time(sc for chart data and IB for level 2 and market depth)? |
[2017-06-11 01:22:52] |
You can do this, but when using the Sierra Chart Exchange Data Feed when Sierra Chart is connected to Interactive Brokers, you will still not see the market depth data for stocks. You will have to view that data in Trader Workstation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-26 00:22:22] |
User745789 - Posts: 173 |
Any change on this? Edit. solution: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks Can't have SMART in symbol settings. Bad: ???-STK-SMART/ASX Good: ???-STK-ASX Date Time Of Last Edit: 2019-04-26 00:32:49
[2019-04-26 02:26:17] |
Yes that is the documentation we would have referred you to.
