Date/Time: Sun, 12 May 2024 20:41:53 +0000
Quote Spredsheet deleted or disappeared into black hole
View Count: 668
[2017-06-08 21:45:25] |
User845611 - Posts: 13 |
For the second time in 2 weeks, I tried to open the spreadsheet but nothing opened. The file name and modified time is listed in the 'open spreadsheet window' but selecting and clicking opens nothing. What the hey happened. (twice now)I opened & closed it this am several times. Is it operator error or what? I clicked 'save/yes' when closing. By the way is it necessary to click yes if no changes are made?
Date Time Of Last Edit: 2017-06-08 22:20:09
[2017-06-08 22:02:29] |
Go to the CW menu. Do you see the Spreadsheet listed there? If so, select it from the list. It could be offscreen. By the way is it necessary to click yes if no changes are made? No it is not necessary.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-08 22:02:54
[2017-06-08 22:34:27] |
Yes it is available in CW but the file listed in File> open spreadsheet> file will not open any spreadsheet. I minimized SC and it is not underneath. I can use CW ok but can you tell me why it will not open through the file menu?
[2017-06-08 23:02:42] |
It is opening. It is just not visible. After selecting it from the CW menu select Window >> Maximize to bring it into view.
