Date/Time: Sun, 12 May 2024 10:05:24 +0000
slope calculation
View Count: 1096
[2017-06-08 19:54:48] |
onnb - Posts: 661 |
In SC, I can color subgraph based on slope. When you are doing determine if subgraph is rising or declining, do you use FormattedEvaluate style comparison? |
[2017-06-08 20:17:57] |
It is not likely although we would have to check.
[2017-06-08 20:18:40] |
onnb - Posts: 661 |
ok, not urgent
[2017-06-08 21:00:05] |
The comparison uses actual values without regard to the Value Format and the documentation has been updated.
