Date/Time: Sun, 12 May 2024 04:56:55 +0000
Numbers Bar
View Count: 566
[2017-06-08 11:08:30] |
User75096 - Posts: 48 |
since 1566 the close marker/down box with style: candelstick is not working, not coloring, could you please fix it, thanks
[2017-06-08 14:49:25] |
We have resolved this and we will have a new release out today.
[2017-06-08 15:21:10] |
many thanks and i will thank you for your incredible job , sierra is awesome
[2017-06-08 15:51:57] |
Update now with Help >> Download Prerelease. The problem is resolved. Here are instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
