Date/Time: Sun, 12 May 2024 04:26:25 +0000
Issue with Futures Rollover
View Count: 847
[2017-06-08 03:05:03] |
User772556 - Posts: 21 |
For some reason my roll over date on the ES is kicking in early. It is showing the September contract starting today. During the trading day today it looked fine but when I opened up the chartbook again in the evening it is now showing June 7th as part of the September Contract which is very low volume and not the same as what I was looking at earlier during the trading day. Roll over should be effective tomorrow I believe. How do I fix this? |
[2017-06-08 06:25:20] |
You need to uncheck the option in Chart >> Chart Settings to automatically rollover a futures contract. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#AutomaticallyRollover Once that is done, you can then change the symbol back to the June contract. Refer to: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-08 13:56:25
