Date/Time: Tue, 14 May 2024 12:43:23 +0000
ACSIL SCSubgraphRef & SCInputRef control which display in the study header
View Count: 1012
[2017-06-08 02:56:21] |
User553714 - Posts: 184 |
Hi, Once you ".Name" a SCSubgraphRef or SCInputRef it seems that they are automatically displayed on the top line of the GraphRegion the study applies to; many of my studies name the Subgraphs and Inputs as a matter of course so that they can be used in calculations. What is happening is that so many of them get displayed at the top of the study that the ones I would really like to pay attention to get lost in the "noise" of too many being displayed. Some don't get displayed at all and go off the screen as I can have over 100 Subgraphs and Inputs. My question; is there a way that you can control which named SCSubgraphRef or SCInputRef get displayed at the top of the study GraphRegion? If there isn't a way, would you please consider adding some sort of ACSIL DisplayFlag that can easily be added to avoid them being displayed in the study header; Something similar to "DRAWSTYLE_IGNORE" but for the study header text? This is not urgent or a must have but I think it would great to be able control this behaviour. Thanks for your help & Regards |
[2017-06-08 08:07:41] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingStudyNamesValuesVWRDL In the case of Study Inputs they can be fully hidden or displayed. They cannot be individually controlled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-08 08:07:54
