Date/Time: Fri, 10 May 2024 02:18:59 +0000
How to overlay previous day session's TPO based POC on today's Time/Renko/Range bar chart?
View Count: 1277
[2017-06-07 21:43:58] |
User68474 - Posts: 195 |
I know how to use the Study "Daily OHLC" on a dedicated "source" chart (usually a 1 minute interval) and then use "Study Price Overlay" to then create "Previous Day OHLC" reference lines on any given "destination" chart, be they time based or Range/Renko, etc. I also know how to use the "TPO Value Area Lines" study to lay down the current intraday horizontal reference lines on any given chart, choosing either to include Value Area lines and POC, or, if I wish, to "Ignore" the VA lines subgraphs and use only the POC. What I'd like to do is lay down the PREVIOUS Day Session's TPO based POC as a horizontal reference line from a "source" chart onto any given Time/Renko/Range etc. chart contemporaneously during any current Day Session. I can't quite figure out how to do this. Would appreciate advice.
[2017-06-08 08:11:34] |
With the TPO Value Area Lines study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=158#TPO_Value_Area_Lines Set the Reference n Periods Back Input to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
