Date/Time: Mon, 05 Oct 2026 02:26:28 +0000
Transparency Level for Fill Styles settings has disappeared
View Count: 1952
| [2017-06-06 18:47:44] |
| Zosimus - Posts: 345 |
The Transparency Level for Fill Styles settings is no longer on the Global Settings >> Graphic Settings - Global >> Other. Image is attached. PreRelease 1566 |
| [2017-06-06 21:07:56] |
This has been moved to the Subgraphs tab of the Study Settings window. The documentation has been updated already.
| [2017-06-06 21:37:32] |
I think the documentation here still needs to be updated Chart Studies: Using Transparency
| [2017-06-06 21:52:40] |
We just checked and it is already up-to-date.
