Date/Time: Sat, 18 May 2024 14:10:10 +0000
cancel all orders when flat
View Count: 640
[2017-06-06 09:27:42] |
User884550 - Posts: 149 |
is there an option to automatically cancel all existing orders when position is closed? if not, can you pls add this? |
[2017-06-06 18:14:22] |
You just need to use the Flatten and Cancel command: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#FlattenCancel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
