Date/Time: Sat, 18 May 2024 15:56:40 +0000
RETRACEMENT TOOL
View Count: 802
[2017-06-04 23:55:20] |
Crtfyd - Posts: 277 |
downloaded the latest version. Whats going on with the Retracement tool? It only shows 7 levels. I have to scroll to see the rest of my levels. When I had more levels than could be shown with the size window b4, I just dragged the border to make the window better then all the levels showed. Now, even if I enlarge the window only 7 levels show, and I'd have to scroll each time to see all levels. Is there something that can be done b4 this corrected? |
[2017-06-05 00:07:53] |
You should see 8 levels. We will see if we can increase it to 10. This is designed for efficiency, and no this most definitely will not change. It was very inefficient the way it was before. This was a critical improvement that took a lot of time and effort on our part to implement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-05 00:38:52] |
Yes, i can see how a smaller amount default shown would be advantages to some. But why couldn't the window be "stretched" like b4 to allow more to be shown when the window opens, thus giving both the option for preference? I guess you're saying something I don't understand as far as a critical improvement. B4, it would open to what you had the window stretched to b4 closing it.
[2017-06-06 17:09:07] |
We can increase the number of displayed levels to 12. But we need to keep it to a minimum for system and efficiency and stability of Sierra Chart. The Windows operating system has trouble with too many levels. Because each control on that window is considered a window.
