Date/Time: Wed, 08 May 2024 01:06:23 +0000
spreadsheet number format for bonds
View Count: 1609
[2013-08-26 13:05:34] |
User51517 - Posts: 58 |
Hello How do I configure spreadsheet number format for bond futures? I tried fraction, but it changes 16/32 to 1/2 or 8/16. I would like a customized format x/32. Thanks Date Time Of Last Edit: 2013-08-27 03:46:19
[2013-08-27 01:39:07] |
This is supported in the non-CLR version of Sierra Chart. Although the Spreadsheet functionality is still under development in the non-CLR version. We expect this to be fully ready soon though. Are you using the Spreadsheet study or are you entering Quote Requests on a Spreadsheet? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-27 03:45:56] |
I'm using spreadsheet system for trading. I would like to see price quote displayed as x/32 or xx/32. This is the screenshot with OHLC price quote highlighted: http://www.sierrachart.com/image.php?l=1377574577771.png I also noticed T4 is not supported on the non-CLR version. It seems I have to put up with this issue for a while. I'm assuming the vast majority of SC clients are using regular version. Is there anyway you can consider bringing this feature to the regular version? Thank you |
Number Format.jpg / V - Attached On 2013-08-27 03:32:33 UTC - Size: 258.29 KB - 432 views |
[2013-08-27 04:17:04] |
For the Spreadsheet System for Trading study you will need to stay with the CLR version for now. This is a feature still under development in the non-CLR version but at this time you can begin to explore the new spreadsheet functionality in the non-CLR version. T4 is now fully supported in the non-CLR version at this time. The non-CLR version is intended to become our main version in October. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
