Date/Time: Sat, 18 May 2024 23:42:36 +0000
Study Sub graph Multiply Missing Input for sg1 sg2 etc
View Count: 605
[2017-06-01 12:02:18] |
User360283 - Posts: 440 |
For example I want to multiply the second MA SG2 of the moving averages or the ZigZag line length SG4. Help please. |
[2017-06-01 17:31:58] |
This is the study that you need to use: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=284#Study_Subgraphs_Multiply Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-01 17:51:10] |
I want to multiply by a constant variable.
[2017-06-01 18:08:49] |
It would be best that you create your own custom study to do what you want. You can modify the existing study. Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
