Date/Time: Sat, 18 May 2024 13:22:53 +0000
Whats wrong with quote board?
View Count: 1328
[2017-05-31 19:25:54] |
GPST10 - Posts: 139 |
Symbol EU6 daily change - (-1.00110), verified from CME (+1.00495) Gold -2.2 vs CME +8.3 ..........etc.... Whats the problem? Date Time Of Last Edit: 2017-05-31 19:33:44
[2017-05-31 19:36:11] |
This would indicate there is a problem with a settlement prices from the CQG data feed you are using. We cannot help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-31 20:09:29] |
I checked the procedures for settle and looks like the SC quote board "daily change" is showing the change from current settle while technically i understand it would be more practical to show in the same way the CME is showing it, settle field is separately available anyway. I can use "change from open" but there is no "change from open percent" available - can you add it? |
[2017-06-01 17:13:34] |
The Daily Price Change must be calculated using the most recent settlement price. This is how the CME calculates it.
[2017-06-01 23:27:04] |
When you go to the official CME page and see quotes after the settlement times in early afternoon you will see it is not the case and daily change is daily change represented correctly. Really doesn't matter, just saying.
[2017-06-05 18:31:05] |
All that we are observing is after the current day settlement price is made available, then the Daily Price Change will be relative to that .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-05 18:31:27
[2018-03-16 19:20:50] |
User428493 - Posts: 20 |
... there is no "change from open percent" available - can you add it?
Is it possible to add "change from open percent" field to QuoteBoard? |
[2018-03-16 22:06:00] |
One more thing about QuoteBoard. I can't use the "name" field for symbol description because it's too long. Insted I add "comment" field and write my own description for every symbol. It looks and works perfect. But there is one big problem: when futures rollover and symbols change, all my comments dissappear. There are a lot of symbols in my QuoteBoard, so it takes much time to write new comments :( Maybe you could add "locked comment" field (which won't depend on symbol) or solve this problem in any other way? Hope it's possible. Here is the picture of my QuoteBoard: http://www.sierrachart.com/image.php?Image=1521236778553.png Thank you for your work! |
[2018-03-26 04:58:03] |
Yes we can do what you ask for in post #7. Post #8 is difficult. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-26 06:48:31] |
Thank you very much! If it's not too difficult please consider to add "percent change since yesterday close" too.
