Date/Time: Fri, 17 May 2024 22:15:26 +0000
Trade Activity Log Syncing
View Count: 786
[2017-05-30 23:36:52] |
User509820 - Posts: 69 |
Hello, I use Sierra Chart on a desktop and on my laptop on the road. The issue I am having is that the data in the TAL does not sync all the trades for the same account. I am only seeing data base on what I have made on each separate computer, instead of altogether. I figured it would display all trades for the specific account. Is there a way to see all the data?
[2017-05-31 06:18:51] |
The issue I am having is that the data in the TAL does not sync all the trades for the same account. I am only seeing data base on what I have made on each separate computer, instead of altogether. Yes this does make sense.You will need to export and import the order fill data. Refer to: Trade Activity Log: Importing and Exporting Data If you also use the new CTS low-cost connection model, then you will be able to get what you want without having to do any exporting or importing. Refer to: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-31 06:19:42
