Date/Time: Sat, 18 May 2024 21:38:14 +0000
[User Discussion] - Range per Bar setting
View Count: 772
[2017-05-30 03:14:18] |
User223734 - Posts: 101 |
The "Range per Bar" in "Order Flow", what is different between a longer (eg. 10) and shorter (eg. 5) "Range-Per-Bar"? OR How to define the correct valve of "Range-Per-Bar" for each product (eg. ES futures)? |
[2017-05-30 17:37:48] |
There is no correct value to use. You need to use the number of ticks that you want for Range bars. 5 or 10 ticks should be just fine for a Range bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
