Date/Time: Sat, 18 May 2024 17:29:56 +0000
Alert when CCI is 50-points Higher than
View Count: 1110
[2017-05-30 00:11:00] |
JayShea - Posts: 92 |
the lowest of the last 10-bars and that lowest bar is <-100. I've looked (I believe) carefully at Study/Chart Alerts And Scanning: Alert Condition Formula Format for a max value classification. I see Highest/Lowest over N-Bars but that doesn't seem to be what I want. Am I missing something? Certainly grateful for a nudge in the best direction. Thanks & Cheers, JD |
[2017-05-30 04:09:55] |
Unless we are misunderstanding what you want to do, you will definitely want to use this study and have the Alert Condition Formula make reference to it: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=54#Highest_High_Lowest_Low_Over_N_Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
