Date/Time: Sun, 19 May 2024 03:16:02 +0000
Conflicting price reading on P and f
View Count: 1009
[2017-05-29 23:01:50] |
madra - Posts: 109 |
Hello, Amzn daily p&f chart reads last price 993.38 IB brokers last price 995.78 I volatility 995.78 seems this may be the price for may 18 How to fix this? http://www.sierrachart.com/image.php?Image=1496098272204.png amzn 15 min p&f chart reads last price reads 961.25 Seems this is price for may 16th How to fix? http://www.sierrachart.com/image.php?Image=1496098629621.png What is going awry here? |
[2017-05-30 00:28:57] |
What kind of the question is this? How to fix what? What you see is based upon how the Point and Figure study works, its Input settings and the 15 minute underlying data in the chart. All of this is fully documented. We make reference to the 15 minute underlying data because that is the underlying data we see in the chart images you posted. We do not understand what you are trying to say here: Amzn daily p&f chart reads last price 993.38 IB brokers last price 995.78 I volatility 995.78
If you are going to post something here and take our time, you need to be very clear about what you are saying and have a proper basis for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-30 00:31:43
[2017-05-30 00:57:08] |
Quite feisty response! The amzn daily chart on my computer only shows a reading only up to May 18. how do I have the chart extend to May29 http://www.sierrachart.com/image.php?Image=1496105575997.png How do I fix it? It's the same story for amzn 15 min chart http://www.sierrachart.com/image.php?Image=1496105735609.png Thank you |
[2017-05-30 01:18:26] |
We assume that you understood that these charts are not scrolled to the end? We thought you intentionally scrolled them back to show us something that you are asking about. Select Chart >> Goto End of Chart.
