Date/Time: Sat, 18 May 2024 19:51:10 +0000
Data disappears on Monday
View Count: 642
[2017-05-28 18:59:46] |
User472677 - Posts: 316 |
Hello, Please point me towards the setting that is causing this abnormal behavior. On every Monday at 9:30 am when stock market opens all data from my all intraday charts disappears. My charts are set for prepend data which comes in normally until 9:30 am.it is like a reset. After all data disappears, new data comes in normally For example on a chart set to 1 minute, at 9.31 there will be ONLY one bar. Rest of the chart Will be empty. It is s global setting as it happens to all charts. |
[2017-05-29 01:24:32] |
This is caused by a particular study you are using. One of them is causing the chart to reload and adjusting the Session Times. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
