Date/Time: Thu, 02 May 2024 11:57:28 +0000
P and F Support
View Count: 723
[2017-05-27 03:11:10] |
madra - Posts: 109 |
Hello, I seem to have a wrong setting. the daily chart is fine but when use a lower time frame this what I get: second screen shot http://www.sierrachart.com/image.php?Image=1495854227514.png daily chart http://www.sierrachart.com/image.php?Image=1495854420176.png 4H chart Is there some adjustment that I can make so that shorter time frames will populate the screen? Thank you |
[2017-05-27 05:53:24] |
Do not use the Point and Figure study. Instead use the Point and Figure Bars Bar Period Type iin Chart Settings. Refer to the documentation here: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) The most important thing to do is to use a small box size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-27 18:22:21
[2017-05-27 18:19:29] |
Not sure what you mean by 'don't use p and f' study. Use p&f bars. do you mean p and f ophlc bars? this is still not right notice the screen shot the bars are bunched on the left of the screen http://www.sierrachart.com/image.php?Image=1495908192226.png http://www.sierrachart.com/image.php?Image=1495908976347.png the daily screen is better but no better than pf x and 0 http://www.sierrachart.com/image.php?Image=1495908712806.png http://www.sierrachart.com/image.php?Image=1495909009877.png I would also like to know why the x and 0 does not work. This what I am familiar with. Will the x and 0 give a false reading? has Scierra any plans improve this? Thank you, charlie |
[2017-05-28 17:19:07] |
In the case of Intraday data, increase the amount of data in the chart. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data That should solve the problem. Not sure what you mean by 'don't use p and f' study. Use p&f bars. What we are referring to is the Bar Period Type >> Point and Figure Bars in Chart >> Chart Settings.I would also like to know why the x and 0 does not work. What do you mean by this?Will the x and 0 give a false reading? has Scierra any plans improve this? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-28 22:29:42] |
Thanks for the help. I've got it
