Date/Time: Fri, 03 May 2024 15:06:52 +0000
Help with custom study
View Count: 821
[2017-05-26 19:17:20] |
User953894 - Posts: 58 |
I know your policy is that you don't do custom programming. I had a developer who is more of an MetaTrader 4 programmer convert and MT4 indicator to a Sierra Charts study. The study works, in fact in works pretty well, but it seems to not be efficient. It works well on some simple charts but seems to take a long time to load on other charts. I'm hoping one of your programmers can take a look and find (and fix) any inefficiencies. I've seen about a dozen requests on your support board and on other forums to have this indicator converted. I would be happy to share this study with others, even put it on your list of user studies if you prefer. I've attached the study. Thanks for considering my request. |
Private File |
[2017-05-27 00:38:10] |
I noticed the new functionality that displays a time next to each study on a chart. For the usual studies I see from 0-12 ms. For this custom study, I loaded and it showed over 17000 ms. I reset one of the input variables and the time went to 55000ms.
[2017-05-27 05:45:30] |
The study is clearly very inefficient based on those times. Also the DLL is not of any use at all to anyone in order to find a problem with it. The actual source code is what is needed. This file has a CPP extension. Contact Jim _At_ sierrachart.com. They can handle this for an additional cost. Assuming they have the time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
