Date/Time: Sun, 28 Apr 2024 09:18:39 +0000
non stop flashing chart
View Count: 963
[2017-05-26 13:41:51] |
User461746 - Posts: 11 |
When I select NISS-NYSE for a symbol and try and open up and intraday chart it flashes non-stop and will never stop
[2017-05-26 14:24:07] |
When I try and open any symbol it non-stop flashes also
[2017-05-26 15:04:32] |
Do you mean you notice a flicker of the chart graphics when it is updating? This should never happen. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-26 15:11:18] |
Thanks for your response, the chart does not flicker, the entire chart blinks continuously and seems to never fully load. The heading flashes between 1min 15min and 30min. pretty weird
[2017-05-26 15:31:49] |
This is due to a circular reference. In newer versions of Sierra Chart this will be detected and stopped. You are running an older version of Sierra Chart. You can update with Help >> Download Current Version. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-26 15:32:15
[2017-05-26 15:51:20] |
You got it! I had 2 charts linked and when I unlinked them it loaded fine. thank you |
[2017-05-29 17:55:21] |
Neo - Posts: 198 |
How can I get my charts to flash? Would be good to have them flash based on an alert condition.
[2017-05-29 18:11:53] |
You cannot. You have a misunderstanding about what the user is describing. You can use ACSIL to change the background color of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-29 19:50:02] |
Neo - Posts: 198 |
I understood what the user was saying. It just made me curious as to if there was a way to programmatically achieve this inside ACSIL.
