Date/Time: Fri, 03 May 2024 06:53:45 +0000
Different Forex spreads between SierraChart and TradingStation on FXCM account
View Count: 956
[2017-05-26 09:52:07] |
AlexPereira - Posts: 197 |
Hi, I have a FXCM standard ( NDD ) account. I noticed that the spreads on SierraChart and the spreads on TradingStation ( readonly ) don't match. Before using SierraChart, spreads on forex are usually between 0.1 and 0.5 ( on EURUSD for example ). See attached image with the example of the first four forex pairs. I only noticed this now, because I use my other account ( LMAX ) for forex trading. Thanks ! |
Private File |
[2017-05-26 16:56:40] |
We need to ask FXCM about this. What is Global Settings >>Data/Trade Service Settings >> Service set to? And what is the Server set to in the list of settings below the Service setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-29 07:22:27] |
Hi, My Data/Trade Service Settings is set to : "FXCM Live Trading (Standard) - DTC" the server is : "FXCM LTD EURCFDREAL Server" Thanks |
[2017-05-30 05:33:03] |
This should be resolved in about 15 minutes.
