Date/Time: Sat, 18 May 2024 18:46:34 +0000
new feature question
View Count: 821
[2017-05-25 20:22:40] |
User103949 - Posts: 78 |
Hi, At the end of last year I was told you are considering developing the feature to read market data directly instead of from the chart. Is that still on the plan? Thanks |
[2017-05-25 21:37:03] |
We are not sure what you are referring to. It does not make sense to us.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-25 21:37:36
[2017-05-28 21:22:57] |
Let me make myself clear. I am developing trading strategies which requires tick data for specific product. I have to set the chart to display tick level data and read the data from sc.BaseData into my advanced custom study. I was told you are developing a feature that can allow user to get market data directly. Is that still on your plan?
[2017-05-29 18:50:37] |
a feature that can allow user to get market data directly. Are you referring to the current real-time data or past historical data?
[2017-05-29 20:19:00] |
User938699 - Posts: 2 |
Hi, I have a questions. I want to use the Diagonal Comparison of Bid Volume and Ask Volume setting, but I can not find it. What is the problem? Thanks. |
2017_05_29_21_54_45_Numbers_Bars_Sierra_Chart.png / V - Attached On 2017-05-29 20:17:49 UTC - Size: 131.04 KB - 230 views 2017_05_29_21_53_10_.png / V - Attached On 2017-05-29 20:17:58 UTC - Size: 96.14 KB - 244 views Attachment Deleted. |
[2017-05-29 20:35:52] |
You need to update Sierra Chart to the current version. Follow the instructions here: Software Download: Fast Update Also this thread that you posted in is unrelated to your question. You needed to start a new Support Request. Here are the instructions for that: https://www.sierrachart.com/index.php?page=PostingInformation.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-29 20:36:41
[2017-05-29 21:46:28] |
For some reason, other people's question was posted after my post. not sure sure why. Regarding to my own question, I am referring to real time data. Thanks, |
[2017-05-29 21:55:14] |
Therefore, we recommend that you use the Time and Sales data. If you just need the recent trades, that is the best way to access it efficiently: sc.GetTimeAndSales() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
