Date/Time: Sat, 18 May 2024 22:03:49 +0000
Non Back Adjusted Continuous Contracts?
View Count: 819
[2017-05-25 14:10:10] |
User791167 - Posts: 22 |
Hi, I'm looking at the continuous contract options and I am not seeing a non back adjust option.... Or is this what is labeled as 'Forward Curve'? Any help here would be appreciated. Thanks |
[2017-05-25 17:16:35] |
No you do not want to use Forward Curve. The second and third options do not do back adjustments. Refer to: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#RolloverOptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-25 18:31:51] |
Ok, Thanks!
