Date/Time: Sat, 18 May 2024 11:29:00 +0000
Font size
View Count: 1173
[2017-05-25 01:56:41] |
SY Tong - Posts: 28 |
Hi Support team, this morning when I opened the chart, the font size became unreadably small. I click on Global settings but I cant change the font size there. Please help! Thank you, Carol |
Screenshot 2017-05-25 09.53.57.png / V - Attached On 2017-05-25 01:55:46 UTC - Size: 408.98 KB - 252 views |
[2017-05-25 03:07:30] |
Why cannot you change the font size through Global Settings >> Graphics Settings >> Fonts? If it has no effect, then you need to set it through Chart >> Graphics Settings >> Fonts. Here is the relevant documentation: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-25 03:08:36
[2017-05-25 03:19:20] |
Thanks for your reply. However, in both your methods, the font size cannot be adjusted... I am using a magnifying glass to help read the charts! Please I really need to resolve it! Regards, Carolina |
Screenshot 2017-05-25 11.17.01.png / V - Attached On 2017-05-25 03:18:29 UTC - Size: 408.97 KB - 221 views |
[2017-05-25 06:35:21] |
It is not clear to us what the problem is. Can you go to the Fonts tab, select Chart Text and press the Select button. Provide a screenshot of this. You may have to select a different Font. If you cannot change its Size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-25 06:35:42
[2017-05-26 01:41:07] |
Hi I tried this already. I can change some of the font size in the chart through this way, such as the words on the top and bottom of the page. However the main concerns are those numbers indicating the time line and the index level of the charts.
[2017-05-26 04:51:54] |
The Chart Text font setting on the Fonts tab affects the entire chart.
[2017-05-31 02:43:23] |
Hello, Is there any other you can help me regarding the font size? I really cant do anything else myself. Thank you. Regards, Carolina |
[2017-05-31 02:48:27] |
Hi, I just managed to change the font size!!! Yay!! Thank you!!! Regards, Carolina |
[2017-05-31 03:05:26] |
OK this is good.
