Date/Time: Mon, 20 May 2024 18:06:49 +0000
Is there a maximum position limit feature?
View Count: 705
[2017-05-24 14:48:55] |
User772556 - Posts: 21 |
Can I setup a maximum position size somewhere? To avoid making errors and putting a larger than desired position size. Thanks, |
[2017-05-24 18:15:06] |
Usually the trading service you are using can set this for you on their side. Check with them. This is only supported with automated trading in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
