Date/Time: Mon, 20 May 2024 13:48:29 +0000
OHLC Open/Close line
View Count: 1137
[2017-05-24 11:00:48] |
lpfin123 - Posts: 59 |
Good morning, Is there a way to adjust the width or the Open/Close line on OHLC bar? I'd like the close of the previous bar not touching the open of the current bar (see attached file). 1) I know there is an option to increase the thickness (under "Graphic Settings") 2) Even using Chart/Bar Spacing, the close/open line will still touch and there won't be any space between them. Thank you for your time, |
17-05-24.JPG / V - Attached On 2017-05-24 10:56:03 UTC - Size: 193.89 KB - 284 views |
[2017-05-24 18:12:18] |
It is controlled with this particular setting in Global Settings >> Graphics Settings: Graphics Settings: OHLC Width % (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
