Date/Time: Mon, 20 May 2024 20:40:37 +0000
About TradingTriggeredLimitOrderEntry.cpp
View Count: 899
[2017-05-23 19:09:28] |
User401662 - Posts: 16 |
Hello, I read on another thread that the TradingTriggeredLimitOrderEntry.cpp study is the only way to use negative offset for stop limit orders as they are not "natively" supported (maybe it has changed?). If this is the case, is it possible to use shortcuts for "Set Trigger Price" and "Cancel Triggered Limit Order"? I'm using stop limits orders with negative offset in my strategy and it's not very convenient and to right click and choose them in the menu (see screenshot attached). Thanks for your help. |
[2017-05-25 03:11:49] |
A negative offset cannot be used for a Stop-Limit order because it will be rejected by the trading servers. If this is the case, is it possible to use shortcuts for "Set Trigger Price" and "Cancel Triggered Limit Order"? Yes, but we do not know how through the use of keyboard shortcuts this would set the prices. You would have to modify the study. Here is the relevant ACSIL documentation:Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events You will need to use Control Bar buttons and can assign keyboard shortcuts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-25 03:12:56
