Date/Time: Mon, 29 Apr 2024 13:25:51 +0000
chart updating
View Count: 1208
[2013-08-24 15:34:05] |
Eliska Petraskova - Posts: 4 |
My intraday chart YM overlayed by ES and RJ finish with the date of 5th August 2013. If I Edit/Download data it created a date gap, followed by only the day 21st August. What shall I do? Nothing like that happened before. All the data got updated automaticaly after opening. Thank you
Date Time Of Last Edit: 2013-08-24 15:34:44
[2013-08-26 03:27:06] |
Refer to help topic 7 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
