Date/Time: Sun, 05 May 2024 08:29:48 +0000
A additional Sierra Charts feature
View Count: 608
[2017-05-21 16:21:55] |
User35326 - Posts: 57 |
SC: I have an additional feature idea for SC. If I have two chartbooks open, for example, and one chartbook has 3 separate charts in it, it would be great if there was a feature to duplicate all 3 charts at once into another chartbook. This assume's that the receiving chartbook has a few charts in it already. That way, instead of having to do 3 separate duplicate to chartbook functions, it could be done all at once. I will send you my bill for the trading software engineering idea. :) Or, you can add me on your payroll for support since I am a Sierra power user. You can look back at my prior posts and see more of my other brilliant additional feature idea posts. For example, the show compact tool values window where the information can be displayed horizontally in order to place this info into what had been unused space on the traders screen(s). Good trading and software engineering to you. Date Time Of Last Edit: 2017-05-21 16:23:10
[2017-07-21 21:45:12] |
This has been added. Also the horizontal Compact Tool Values Window was something that was planned and implemented long before any user suggested that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
