Date/Time: Mon, 20 May 2024 10:21:10 +0000
[User Discussion] - Pc build $ best spent
View Count: 932
[2017-05-21 14:23:10] |
User343047 - Posts: 16 |
Hey guys I'm looking to build a trading pc. I understand in general terms cpu power, multiple cores, ssd, more ram is always better. In more specific terms where will my money be best spent? I will be running SC and infinity platform only nothing else will be running or even installed on pc.im not sure if 4 cores will even be utilized over two. Or would I be better served with a dual core but better clock speed or more ram so on. I know this is a loaded question but I'm just looking for some quick guide not a detailed answer thank you
Date Time Of Last Edit: 2017-05-21 14:24:17
[2017-05-21 17:36:59] |
You should definitely get a quad core CPU with 16 gigabytes of memory and an SSD. These are the basic minimums.
[2018-03-05 17:47:37] |
sjk - Posts: 43 |
Basic minimums aside, what is the best for using SC?
