Date/Time: Sat, 27 Apr 2024 13:15:12 +0000
Maximum number of studies in a chart ?
View Count: 2696
[2013-04-03 10:27:42] |
nepher - Posts: 56 |
Hello ! I try to add a new study in one of my chart but, impossible to do. I notice in my window interface that I reached 255 studies (a lot of coumpound and complex alerts indeed !) in this graph. It seems that it refuses the 256 th. I'm blocked in my work. Is it possible to unlock this limitation ? It will be of great help Thanks for your attention. |
[2013-04-03 15:50:38] |
We do not want to expand this. We recommend using another chart.
[2013-04-05 14:17:07] |
I don't really see how to easily manage the displays with two charts of the same timeframe ?!? -Do you mean to put the intermediate calculations, combinations of my alerts in the first chart ? and in the second I put only the display of the alerts ? if this is the case, nevertheless, all the simple studies need to be duplicate as for calculation to chart one, and the display for chart two, isn't it ? - Does it mean that the studies of first chart are overlays for the second ? - Shall I need to trade with two charts of the same timeframe in front of me rather than only one ? Some of my alerts took three separate studies to be agregate in final in a forth one because the lenght of the text condition exceed the standard space available for a simple alert. If it's not possible to expand the number of studies to 350-400 (that could be great, I have a Core i7) , is it possible to expand the space available for the text in the alert condition ? Thanks for your insight |
[2013-04-05 17:08:35] |
Some of my alerts took three separate studies to be agregate in final in a forth one because the lenght of the text condition exceed the standard space available for a simple alert. http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#GeneralInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-05 17:09:01
