Date/Time: Mon, 29 Apr 2024 15:03:40 +0000
fithmic frankfurt presence
View Count: 883
[2017-05-16 15:34:02] |
User63439 - Posts: 83 |
hi there, had massive connection öroblems.contacted rithmic. they said i should connect via their europe server. then they srote to me i should ask sierra about their frankfurt presence. is there a way to connect to rithmic frankfurt server. thanks in advance |
[2017-05-16 17:57:38] |
No, this is not specifically supported. Sierra Chart does support a connection to the Rithmic Europe server wherever it is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-16 17:57:46
[2017-12-22 06:27:38] |
The Rithmic Frankfurt server is now supported in the latest release of Sierra Chart.
