Date/Time: Fri, 10 May 2024 02:44:28 +0000
Relative Volume Study
View Count: 955
[2017-05-11 01:36:30] |
RonW - Posts: 103 |
With the Relative Volume Study, if "Period - Days to Include" is set to "20", and "Accumulation Type" is set to "Day of Week", does the study reference 4 Mondays, 4 Tuesdays, etc. or 20 Mondays, 20 Tuesdays, etc.?
[2017-05-11 04:00:13] |
It would be the smaller of these two, but more likely referencing the current and the prior 2 weekdays. Not 4. For 4 you really need to be using a value of about 30.
[2017-05-11 11:52:53] |
RonW - Posts: 103 |
Just to clarify... so the "20 days" is 20 calendar days?
[2017-05-11 12:39:50] |
Yes
