Date/Time: Thu, 02 May 2024 03:49:01 +0000
attached orders oco questions
View Count: 1308
[2013-08-22 21:05:55] |
User22396 - Posts: 191 |
2 questions regarding attached orders oco(bracket orders) a) is there a way to use the attached bracket orders (oco) if the market moved away from entry by a distance larger than the oco bracket? --for example filled long cl @ 105.00 mkt rallies to 106.00 and now i want to use a bracket order but my brackets are 20t each side so will it bracket the open position price 105.00 so place orders at 105.20 and 104.80 hence the 105.20 will become a mkt order and be filled immediatley since mkt is currently at 106.00? i didnt want to mess around with a live order so thought i would ask here b) can i create an attached order out of 2 seperate legs after the fact? thanks |
[2013-08-22 22:54:50] |
1. You can subsequently send attached orders based upon the current price and not the average fill price. Here is the documentation for this: https://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#SendAttachedOrders 2. Not totally clear about the last question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
