Date/Time: Sat, 11 May 2024 06:50:38 +0000
Nasdaq refuses to load
View Count: 567
[2017-05-10 16:22:46] |
tellerbe - Posts: 109 |
Nq data refuses to load from 22:28 yesterday until1 1:32 today . Other charts load with no problem.
[2017-05-10 16:28:36] |
Try downloading the data again following these instructions: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-10 20:33:21] |
HOw do I pull up the menu?
[2017-05-10 22:04:11] |
So when you right-click on the chart, do you not see a menu? The simple solution is just to go to the chart and then select Edit >>Delete All Data and Download from the main menu at the top. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-10 22:04:40
