Date/Time: Sat, 04 May 2024 06:01:39 +0000
[User Discussion] - weekly indicator indicator offset error
View Count: 1403
[2013-08-22 20:56:11] |
User22396 - Posts: 191 |
i am tryin to plot an indicator from a weekly chart on a intraday chart using the "Study/Price Overlay" but it will not line up to the sunday intraday chart globex start time correctly it is offset to sunday midnite...i try to change the various setting but then it offsets to thurs/fri evening any help thanks |
[2013-08-23 01:21:29] |
'nearest match' moves the indicator to thurs evening globex start and 'containg match' moves the indicator to sunday midnite start
[2013-08-26 13:18:23] |
hello support is there any way to get this to plot correctly? thanks |
[2013-08-27 03:53:40] |
M5amhan - Posts: 468 |
what is the indicator you are trying to transfer and any indicator you try to transfer from a daily or weekly chart onto an intraday chart will start at midnight unless you have your intraday session times set differently, say instead of Session Times: Start Time: 00:00:00 End Time: 23:59:59 and evening session unchecked You set it to: Start Time: 8:30 End Time: 15:14:59 Evening Session: Start Time: 17:00:00 End Time: 8:29:59 This will have it starting at 17:00:00 which is globex open for ES and if you dont want any data left out set the first End Time to 16:59:59 Date Time Of Last Edit: 2013-08-27 03:58:48
