Date/Time: Fri, 10 May 2024 16:08:26 +0000
Time Range Failure
View Count: 650
[2017-05-10 14:30:30] |
User137998 - Posts: 13 |
Is there any reason for trades to be executed prior to my specified time range. I'm currently trading 10 chartbooks for trial. I have cells J85, J86 & J87 as follows TRUE, 06:35:10 & 12:59:59. 2/10 chartbooks executed trades prior to 06:35:10 this morning. One at 06:30:09 & 06:30:51. Any advice would be excellent! |
[2017-05-10 16:17:15] |
PLZ Diregard
[2017-05-10 17:05:32] |
From our perspective since we do not know exactly what you are doing or observing the problem, it is hard for us to answer this. The functionality does work correctly. We did make a documentation update with some additional information. Refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#AllowTradingOnlyDuringTimeRange Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-10 17:05:56
