Date/Time: Sun, 12 May 2024 06:37:53 +0000
SC DATA - ALL SERVICES
View Count: 726
[2017-05-10 13:30:54] |
User700756 - Posts: 16 |
I am wanting to get quotes on ES OPTIONS. EXAMPLE - ESM2400C I subscribed to GBLX data (No trading account) and get the following message when i try to download the data for this symbol SC DATA - All Services | Subscribing to streaming market data in the service client is not supported. Symbol ESM2400C ... It doesn't complain about the symbol and attempts to download some data but the file is empty. I followed the instructions in the documentation regarding this error message and updated the symbol list and re-started SC. After reading on the support board it appears that options data is not available through SC Data feed? I just want to clarify that i'm not doing something incorrectly before i go off looking for another data provider for options data. Is there a preferred options data provider or can you recommend one for sierra charts? Thanks, |
[2017-05-10 22:40:41] |
The only futures options data that Sierra Chart provides is historical Daily chart data. Not Intraday data or real-time data. At the moment, you will need to use IQ Feed for options data if you do not have a trading account: DTN IQ Feed Data Service We do intend to offer CME futures options data this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
