Date/Time: Fri, 10 May 2024 04:00:51 +0000
Extension of trial
View Count: 615
[2017-05-10 08:22:24] |
grantx - Posts: 244 |
Could I get an extension of my trial? Its going to take me a bit longer than expected to choose the correct broker and get setup with data, funding etc..once I have it nailed though Ill be subscribing to your platform. Thanks. |
[2017-05-10 16:32:17] |
Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
