Date/Time: Mon, 29 Apr 2024 00:37:35 +0000
Inconsistent Data on two machines - same data source
View Count: 1300
[2013-08-22 19:50:39] |
shanley - Posts: 11 |
Hi guys, Odd one. On the ES, I got a different low on June 23 on my desktop vs our trade room. The attached picture is from my desktop. The left view is my PC which shows a low of 1558. The right is a GoTo Meeting with our trade room where Gary has a low of 1553.50. I did the Delete and Reload - no change. I went back four contracts and did four rollovers - no change. The same problem was happening on my laptop. I went back four contracts and did four rollovers - and now have 1553.50 on my laptop. Still have 1558 on my desktop. Any suggestions ? Appreciate any feedback or suggestions on what I might have out of sync. Thanks so much, Mike |
Desktop 2013-08-22.jpg / V - Attached On 2013-08-22 19:45:58 UTC - Size: 961.71 KB - 445 views |
[2013-08-23 04:50:22] |
June 23 is a point in time near a rollover. The chart may not be showing the correct contract month for that particular day . We recommend using the Continuous Futures Contract Method 1 documented here: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#Method1 And then re-download all of the data for all of the futures contracts as explained in the step-by-step instructions linked to for Method 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
