Date/Time: Sat, 27 Apr 2024 11:20:19 +0000
Quoteboard - move up or down
View Count: 1602
[2017-05-09 02:35:17] |
Kinobe - Posts: 86 |
Hi, I'm after a very simple feature request. In the quoteboard, I d would like to move up or down a symbol with a keyboard shortcut. thank you very much |
[2017-05-09 03:00:32] |
This can be done through Settings >> Set Symbols on the Quote Board: Getting Quotes: Setting Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-10 01:30:51] |
If I resume for moving up or down a symbol eachtime, we need from the quoteboard : - click - Settings - click - Set symbol (Symbol list opens) - select the symbol - click - move up or down - close the symbol list (otherwise the change is not being taken into account) - and then the symbol has just moved up/down in the quoteboard what I am looking for, it is a quicker way to move up/down with a keyboard shortcut from the quoteboard directly. For instance, from the quoteboard, by clickin a shortcut like shift+U or shift+D a symbol will move up or down respectively. I move up or down symbols like 20/30 time during a day... Thank you Date Time Of Last Edit: 2017-05-10 01:33:43
[2017-05-11 00:29:16] |
can you consider adding keyboard shortcut as explained? thank you very much |
[2017-05-11 04:54:16] |
Yes we can, but you need to allow up to 24 months.
[2017-05-11 13:47:29] |
But it is also likely possible we may get to this in the short term during the next three months.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-11 13:47:53
[2017-09-06 20:25:16] |
Did you have time to implement this request? thank you |
[2017-09-07 03:07:59] |
No, we do not expect to get to this until next year.
[2017-09-11 19:52:55] |
I hoped you made it within 3 months as you mentionned in your previous post.
[2017-11-28 10:01:22] |
I'm after a very simple feature request. This is actually not a simple feature request and is quite elaborate to implement keyboard shortcuts in this way because they have to be done in an organized and unified way with other keyboard shortcuts. It is actually very involved.In the quoteboard, I d would like to move up or down a symbol with a keyboard shortcut. What we have added is a "Symbols" menu directly to the Quote Board top level menu and added keyboard shortcuts for the Move Up and Move Down buttons on the symbols dialog. So you can move symbols up and down from there using the Alt + U and Alt + D keys. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-28 10:01:50
[2017-12-12 03:45:59] |
Thank you for this solution. But it is nearly as long as before except the shortcut in the Symbol List. I was looking for a shortcut in the Quoteboard not in the Symbols list. Imagine at the opening, you have 10/15 stocks to watch and you need/want to filter/order them in the Quoteboard in order to focus/play just 2 ou 3 of them and this in short period of time. Shortcut in the quotebard directly would be the best option. thanks you for your effort. |
