Date/Time: Mon, 13 May 2024 11:42:52 +0000
error in Exclude Evening Session Profiles Except For Last Day study
View Count: 640
[2017-05-08 13:17:32] |
User968625 - Posts: 256 |
Pls check because yesterday's evening high (2404 at 18.00 @ May 7) is not showing. when I disable the study and enable all evening sessions then it works fine
[2017-05-08 14:00:42] |
The only way this Input is going to work properly is if you follow through the instructions here: Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions The the Session Times in Chart >> Chart Settings must enable and set the Evening Session Times. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-08 14:48:57] |
This is the right setting that I have always had. maybe you need to check that it is not because of the weekend. I think that might be the case
[2017-05-08 14:51:03] |
What are the Session Times in Chart >> Chart Settings set to?
[2017-05-08 14:59:06] |
09:30:00 - 17:15:00 evening session: 17:15:01 - 09.:29:59 |
[2017-05-08 16:57:06] |
Actually thinking about this, this does make sense: Pls check because yesterday's evening high (2404 at 18.00 @ May 7) is not showing.
We can make an adjustment to make this work, but it is only going to be the evening session for the current day which has yet to occur which would be displayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-11 14:46:05] |
I am not sure I follow?
[2017-05-11 15:00:30] |
Update Sierra Chart to the latest release. Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
