Date/Time: Sat, 11 May 2024 05:55:07 +0000
Price levels label and automated
View Count: 1320
[2017-05-08 12:42:28] |
User968625 - Posts: 256 |
Hello, 1- I am trying to add a label to the price level (e.g. overnight High) and would like to see this label anchored on the right without moving. there is no option to do that. I have some levels that I update daily. pls advice how to do that 2- is there a way to automate price levels on the right side. for example, can I have the overnight high always updated to last night and anchored to the right? Thank you |
[2017-05-08 17:02:04] |
1, 2. Use the High/Low for Time Period-Extended study: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=246#High_Low_For_Time_Period_-_Extended Here is the documentation for Subgraph Name and Value labels: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#NameValueLabels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-08 17:02:19
[2017-05-09 17:23:10] |
Thanks but what if I want other values and levels. for example, would like to highlight 1/2 back or would like to see the previous day open. Is there a way to define some levels and then automate them As for the value and label, thank you. that works |
[2017-05-09 20:11:51] |
highlight 1/2 back Specifically what is the definition for this?For the previous day open, use the Daily OHLC study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=137#Daily_OHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-10 00:16:08] |
Kinobe - Posts: 86 |
for 1/2, you can use auto retracement study with only 50%.
[2017-05-11 12:07:01] |
Ok, thank you Kinobe and thank you amazing Sierra team
