Date/Time: Fri, 03 May 2024 01:00:31 +0000
Customize taskbar text
View Count: 1986
[2013-08-22 08:13:45] |
User42282 - Posts: 41 |
Hi, I searched the forum but cant find anything. When running multiple instances of SC, it easilly becomes a mess; hard to distinguish among instances. Is there a way how to customize the text which is displayed on windows taskbar for the program? There is "Sierra Chart" + [version] + [Data/Trade service] + [Date, time] + [Chartbook]... When using SC Historical Intraday Futures Data connection, it is so long text that you can not see chartbook name. I would appreciate any hint, even some low-level way. The solution would be having chartbook name at first, or the path to exe or data folder; maybe some other possibilities. Thank you! |
[2013-08-22 08:26:06] |
Yes. Global Settings >> General Settings >> General 2 >> Custom Title Bar Name. We will see about placing the Chartbook name first. That might be a good idea. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
