Date/Time: Fri, 13 Nov 2026 10:16:19 +0000
Copy chart drawings across chartbooks
View Count: 2482
| [2017-05-03 09:19:26] |
| oicur12 - Posts: 17 |
Dear Support, I have found two replies from support regarding this topic, however they contradict one another. Unfortunately I cannot find any other relevant documentation to confirm this topic. Here are the two posts I'm referring to; Linking Charts across Chart Books and quoteboard across chartbook linked charts not working | Post: 75842 Is it possible to copy chart drawings across chartbooks? If yes, where can i find the documentation? Please advise. Thank you in advance. Best regards. SC version 1544 |
| [2017-05-03 16:55:46] |
One of the answers given was not completely correct. We corrected the answer. We had not fully read what they were saying. What you want to do is supported. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
