Date/Time: Wed, 04 Nov 2026 16:32:05 +0000
Adding Text to Horizontal Ray Tool
View Count: 2399
| [2017-05-02 20:55:04] |
| User624476 - Posts: 33 |
I don't believe this is an option currently but it would be very helpful in marking off levels with some user entered text. The only available option right now is price.
| [2017-05-02 22:34:36] |
| User700756 - Posts: 16 |
I have a custom study on my website that allows you to add custom lines with user defined text and tag that to a custom study button. Check it out. It is "Custom Horizontal Lines with Text" https://sites.google.com/site/beaconcommoditytrading/home
| [2017-05-03 04:18:15] |
This is already supported. Refer to: Chart Drawing Tools: Modify Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-26 18:10:50] |
| User208416 - Posts: 44 |
the modify text does not seem to work with Horizontal ray. Text button is frozen for horizontal ray but works with a horizontal line or line
| [2020-12-28 22:08:30] |
| John - SC Support - Posts: 48419 |
We do not know what you mean by the "Text button is frozen". The ability to add text to a Horizontal Ray is available and works. You just need to right-click on the drawing and then select the option Modify Text. If this option isn't available in your right-click options then refer to the information here: Chart Drawing Tools: Customizing Chart Drawing Shortcut Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
