Date/Time: Thu, 09 May 2024 01:18:38 +0000
NYMEX Conitinuous Contract Symbol for CL and NG
View Count: 2258
[2013-08-21 18:43:50] |
GrigorHagop - Posts: 18 |
I cannot figure out the symbol for NYMEX continuous contract for Crude Oil (CL) and Natural Gas (NG). With symbol CL# I get Colgate Palmolive stock, and with NG# I get Novagold Resources stock. I have experimented with various alternative symbols...but without success. I thank you in advance for your help. Date Time Of Last Edit: 2013-08-21 22:04:44
[2013-08-21 22:09:37] |
You need to follow step number 2 here to specifically select the Sierra Chart Historical Data service for historical Daily data: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html#UsingSCHDS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-22 14:15:43] |
Thank you for your response. With SC Historical chosen as the data source, I was indeed able to obtain CL# as NYMEX crude. But, when I switched to TD Ameritrade as data source. The Crude Oil title on the chart disappeared and the message came up "Symbol not found" but the data remained unaltered. But, when I switched data source to Interactive Broker, the Crude Oil on the chart label was replaced by "Colgate Palmolive" and the last days data was updated to $58.37, which is Colgate Palmolive's closing price. How can one maintain continuous future charts (e.g., CL# or NG#)if one is not continuously connected to SC Historical as the data source? Thank you again. GrigorHagop |
[2013-08-22 17:59:22] |
The solution to this is documented here: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html#Symbol_Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
